AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,638
- Reaction score
- 13,873
Hyup, that's why I shift at 7000/7200 (yes cast crank, circa 1971, but rebalanced professionally)..
Pour a bottle of Lucus oil treatment in it and twist it to 8000. They sound great after 7500.
It may be on the down side of the power curve but so what; she's still spinning the tires . When I bang it into Second, she drops 1500rpm, right smack dab at peak power; and Bam! it keeps right on screaming. That sound is soooo addictive.
7000 in First-over (GVod) is ~65 mph, so shut down time; turn around and repeat. Then dump the passenger, before his bladder leaks all over my seat.
Second gear, should I chose to use it, is good to 82@7000
The Eighth-Mile is 93@6200 in Second over, or ~5750 in Third, by the math...... which is why the 230/237/110 cam, can stay. Otherwise I woulddapulled it cuz it is pretty hard on gas, lol......
I'm telling you guys, you gotta try alloy heads@ 185 psi on 85E10; you'll never go back to 165, never mind the more typical 155 or less; never.
My engine is nothing special, and the heads are OOTB Eddies. The AirGap was new in 2000 and the 750DP is a factory original mid-seventies model, just upjetted a bit.
The Wallace calculator at my race-day weight(3457) and elevation(900); makes 93 to be 433 hp. I firmly believe that the cylinder pressure is a major factor, in achieving the speed, cz honestly the 230 cam is not IMO big enough by itself..
Eights are impressive for a street machine,at least IMO....
I wish you great success; @318willrun .
