Hello...
I have a non original 8 1/4" axle in a 69 Dart of mine....
It is a 2.71 geared CONE Sure Grip....
I want something better. This car may be getting an A-500 with overdrive so I'd like a 3.55 or a 3.91. That likely means a truck or van.
I'm curious about what donor vehicles I can look for that have a gear set that will fit and work. I read that the 1997 and later models had a different spline count for the axle shafts but I don't know how that would affect the ring and pinion or if it even does.
Who knows what is the cutoff year for the gear set? I'm looking to pull the gears from a donor and install them into this axle using the Sure Grip it already has. The best I can tell is that this is a 1973-76 A body axle. The perches are 43" apart, it does have 11" drums though. No A body that I have ever seen had 11" rear drum brakes so either these have been swapped in or this is some rare and weird setup.
