[SOLD] 8 1/4 sure grip
What does closer have to do with anything? This is the kind of stuff that Greyhound was made for. Just write the information on a piece of paper and tape it to the tube. Go around the paper a couple times with clear tape and it'll get to the destination for around $20.00 It does require terminal pickup and drop off, but so what?
$20.00 to ship a rear(or anything) even by greyhound seems a little cheap. The weight of it & length may be to much for GH.
what are the heads in the pic are the good or cracked
I did an engine swap on a 94 jeep. They are from the one that I pulled. I don't know if they are cracked or not but they wasn't the problem with the engine. It had over 250k on it and a few spun bearings.:oops: I still have it I just tore it down to see how bad inside was. And was cheaper to just put new motor in it.
How can i tell if my 8.25 has a 2.45 or a 2.76 and which one is better to have and why?? please help.............................
Thanks......................... PETE .........................
Pete, if you don't have a tag on the diff cover you'll have to pull the plate off to see. It'll be stamped on the ring gear. As far as better one is just a little taller than the other and one gets better fuel mileage but both are good for that.:burnout: Hope that helps.
