[SOLD] 8.25 rear end
BUCKEYE FAN
Akron, Ohio
Complete Mopar 8 1/4 or 8.25 rear end out of an 69 dart a body. Shock plates and u bolts with nuts included. Drums and backing plates not included.
Located in Akron, Oh 44319
$300
I hope this is taken as a positive and not a "comment" that isn't wanted, but...
The newer gears with Sure Grip carriers and disc brakes from Jeeps and trucks can be installed in these OE 8.25 rears.
All it takes is different carrier bearings.
No OE drums or backing plates needed, as the Jeep disc brake stuff swaps over as a bolt on.
@TrailBeast ....follow up question to hopefully help with
OP's sale. Will the original axle splines from an A body 8.25 work in the newer Jeep/Truck carriers?
They did in mine and it's an original 1973-4 diff.
Just took smaller OD bearings to put the jeep carrier in the OE diff.
It's actually the side gears that matter what the spline is, and they were both 27.
