8 3/4 housing question
65MagnumFish
65MagnumFish
Zeeland, MI
Came across a 8 3/4 rear end housing from a 71 duster. Before I buy it will it fit under my 65 barracuda? I would assume so. Or are spring perches different? It would be a local pickup. Still learning about a bodies and don’t want to get burned. Thanks everyone.
If it needs brake lines you will have to get a set for a 70-72 as sets for 66-69 are different where the vent and brass block go, just an FYI
and that difference will also necessitate a longer flex hose to reach the splitter block location of the 70 and later housing. Not hard to overcome, just go to a local hydraulic hose maker and have one made up.
Rear Axle widths, drum-to-drum:
A BODY ’66-’72: 57-1/8″
Spring perch widths (center-to-center)
A-BODY '66-73= 43"
64 and 65 will have the same dimensions as a 66, they aren't listed because the 8 3/4 wasn't offered those years.
A-BODY '66-73= 43"
Thanks so much all the members here have been so gracious with their time and knowledge. I’ll be buying the rear this weekend. Thanks everyone.
