8-3/4 question
smlveightis
Confused in Confusion
Westland-Meechigan
I did some reading and searches. Just wanted to confirm with those in the know.
I am in the process of buying a 8-3/4" open differential chrysler rear end.
Question is, can I just change the 3rd member with a sure grip unit?
Thanks in advance.
in short...yes
in long, I believe (im sure someone will correct me if I am wrong) you can take ANY 8 3/4 sure grip unit, from ANY case and install it in ANY other 8 3/4 case
so you do not need to buy an entire third member, just the sure grip unit will do
I forget the year you can "Just swap" them. Very early 8-3/4's are not just swapable. I do believe it is a axle spline issue. Buuuuut, I am not 100% on this.
Thank you for the quick response! The rear end is in really great shape, and the price/location are good. Just wanted to make sure first. Thanks again!
The axles are 30 spline so any 8 3/4 diffential with 30 spline count should work
