rednesss
The biggest problem with a lot of the rear brake kits is that they use too large of a piston. With a big rear piston you have to run a huge front piston and then a big master cylinder. If you use a big rear piston with a small front piston you'll end up with a rear bias that you can't fix. The car will spin if you lock the brakes.
Couldn't you cure that with a proportioning valve inserted in the rear brake line??
