.if I remove the yoke will that mess up the lash on the pinion gear
I have a bolt that broke on the yoke....if I remove the yoke will that mess up the lash on the pinion gear
Thanks guys I ended up just removing the whole rear end and taking it to a machinist(after I broke a tap in it)
A grade 8 bolt broke at 20 ft lbs of torque? it must have been a bad one.
