1. KramerSwinger70
    KramerSwinger70 70 Dart Swinger360
    1,019
    4
    Sep 17, 2009
    Rohnert Park, CA
    Local Time:
    4:28 AM
    since Abody 8 3/4's are like gold an the ford 9" is so popular, would it be more cost-effective to use a 9" in my dart? just curious. it'd b nice to get an 8 3/4 just to say its all mopar drivetrain but if i can order a 9" abody length for the same or less than a used 8 3/4 wouldnt i be better off??
    thoughts? has anyone used a 9"er in there abody? or am i simply barkin up the wrong tree here? :read2:
  2. KramerSwinger70
    1,019
    4
    Sep 17, 2009
    Rohnert Park, CA
    Local Time:
    4:28 AM
    then again, i suppose i coudl custom build a mopar 8 3/4 from moser for $2k =/
  3. 1970Duster
    1970Duster Well-Known Member
    6,680
    89
    May 30, 2010
    Local Time:
    4:28 AM
    Yea that is an option over the 8 3/4
  4. 1970Duster
    6,680
    89
    May 30, 2010
    Local Time:
    4:28 AM
    For that much I'd be looking really hard at the Dana 60 with 3.54 gears
  5. KramerSwinger70
    1,019
    4
    Sep 17, 2009
    Rohnert Park, CA
    Local Time:
    4:28 AM
    haha yeah no kidding. im sure i can find an abody 8 3/4 but if i want the clutch style SG w/ 3.23-3.55's...im spendin a VERY pretty penny
  6. 1970Duster
    6,680
    89
    May 30, 2010
    Local Time:
    4:28 AM
    Not really the deals are there you just got to be on the look out for them. I bought a clutch style unit (just the unit from a member here for 260) I got my (spare 489) center section for 75 bucks off craigslist with 323 gears.
  7. rbdart
    rbdart Well-Known Member
    1,920
    18
    Sep 23, 2008
    Golden City Mo
    Local Time:
    6:28 AM
    Rite-on about a-body rears being pricey but worth it over the fraud err I mean ford...getting ready to ship that sg 2day as in above post,and thats shpd price from Mo 2 Ca...getting geared up to cut down all my x-tra 8 3/4 housings into a-body size with spring perches all to factory specs,this will be bare housings,have 6 to do imediately,they will be somewhere between 225-250 depending how much machineshop ends up charging for machining ends out to tube size then welding after fitting and cutting to desired length,pm me if interested...Ken in Joplin Mo...
  8. BrianT
    BrianT Let's go!
    5,503
    1219
    Mar 13, 2007
    Kansas City, Mo
    Local Time:
    6:28 AM
    Don't rule out other vehicles that came with the 8 3/4 rearend. I saw a B body housing only for $150 at a swap meet and the guy said he would take $100 just so he wouldn't have to haul it back home! Don't forget vans, trucks and C bodies also came with that rear.
  9. fishy68
    fishy68 Tyr Fryr's Inc. FABO Gold Member
    16,931
    917
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    6:28 AM
    If you get real real lucky you might find a Ford 9" that's the right length so the price wouldn't be too bad. But that's is you get real lucky. Most likely you'll have to cut down any Ford 9" to make it fit and by the time you do that and buy axles it'll cost more than a 8-3/4 would cost you. RBDart has a good plan on cutting down longer 8-3/4 housings. If you cut them to A body length you can find axles easy and brakes from the 7-1/4, and 8-1/4 bolt up so if your rearend in the car now is one of them you can use them. No good rearend will be cheap for your car, then again their not cheap for anything. A buddy of mine just had a 9" cut down for a big block Chevy pickup and by the time he buys everything he needs he'll have over $1200 in it and it's nothing fancy. Just run of the mill HD 9" stuff.
  10. Dusteriffic
    Dusteriffic Stink finger
    2,605
    542
    Aug 5, 2005
    San Diego, CA
    Local Time:
    4:28 AM
    x2 If I'm in the 2G range, I'm goin' Dana.
  11. duster731
    duster731 young gun
    1,452
    24
    Mar 30, 2010
    Venus Texas
    Local Time:
    4:28 AM
    Ya the deals are there I'm the one that just bought the s.g from rbdart and I got a 741 3.91 third member its going into that I got for free and all braking hardware.... Ask me how
  12. discharger1332
    discharger1332 Well-Known Member
    1,619
    47
    Jan 25, 2010
    silverdale wa.
    Local Time:
    4:28 AM
    how
  13. duster731
    duster731 young gun
    1,452
    24
    Mar 30, 2010
    Venus Texas
    Local Time:
    4:28 AM
    Lol well I found a 8 3/4 on cl out of a dodge a 100 went and got it for 100$ he didn't know the gears and so drug it home it was a complete rear with a 741 3.91 third member I stripped it and kept everythiing and sold the bare housing for a 100$ so essentially you have to invest money to earn money. The deals are out there you just have to look, I also bought a 323 open 741 third member for 50 off of a member here
  14. 67valiant 100
    67valiant 100 go fast or go home
    1,663
    30
    May 3, 2010
    Orange County NY
    Local Time:
    7:28 AM
    ferd :pukel:
  15. srduster340
    srduster340 FABO Gold Member FABO Gold Member
    867
    23
    Jan 17, 2007
    Atlanta,Ga.
    Local Time:
    6:28 AM
    I'd get a B-Body rear. More plentiful, cheaper, & only a couple inches wider. From what I've heard, a 9" from a older Bronco will drop in. Spring perches in the same place.
  16. turbofreek
    turbofreek batcrap crazy racing team
    1,239
    401
    Mar 2, 2009
    kansas city, mo
    Local Time:
    6:28 AM
    I put in a 9" in mine. It's all new and was pricy, but it will never break on me. Mine was custom cut to match wheel offset for a particular look I was after. I also won't have to hunt used classifieds to pick up a part. I can just call any parts dealer and get it quickly. Food for thought for you.
  17. 1970Duster
    6,680
    89
    May 30, 2010
    Local Time:
    4:28 AM
    And this is why you go Dana, Same effect.
  18. Relax360
    Relax360 Well-Known Member
    573
    52
    Jan 6, 2010
    Oceanside CA
    Local Time:
    4:28 AM
    I would take a look at the dana 60 also. I have found them to be just a bit cheaper then the 9 from some vendors. I am getting my setup from Strange.
  19. fishy68
    16,931
    917
    Jan 11, 2005
    Local Time:
    6:28 AM
    Only the old B-body rears are about the same width. In 69 or 70 they widened the b-body rears.
  20. Judge Mills
    Judge Mills 1971 Plymouth Duster
    1,148
    38
    Jan 6, 2009
    Westport, Washington
    Local Time:
    4:28 AM
    I just got done doing a Ford 8.8 conversion.. Total, I'm in to it about 1k. Now, if I had the tools to shorten it myself, and install the new bearings and hot tank and reinstall the differential and new axle shafts, it'd be into it just under 500.....
  21. duster731
    duster731 young gun
    1,452
    24
    Mar 30, 2010
    Venus Texas
    Local Time:
    4:28 AM
    I'm in my b body rear about 550 with a s.g. powdercoated, 3.91 third member and new green bearings
  22. mikedevore
    mikedevore Well-Known Member
    2,623
    175
    Jan 13, 2005
    Oklahoma
    Local Time:
    6:28 AM
    If you were going to modify a 9 inch to fit, why not modify a 9 1/4 mopar axle to fit. These are plentiful & alot of them came with suregrips.
  23. turbofreek
    1,239
    401
    Mar 2, 2009
    kansas city, mo
    Local Time:
    6:28 AM
    No its not. To a point maybe, but how do you keep the axle tubes from twisting? How low can the car sit with the monster center section of a Dana? Lots of issues with tank/floor Clearence if you don't want a 4x4 muscle car.
  24. 1970Duster
    6,680
    89
    May 30, 2010
    Local Time:
    4:28 AM
    I've only seen the tubes on a Dana twist once when a guy went from a 600 rwhp to 1200+rwhp. The rear lived for over 10 years with 600 HP just fine but only the 1200 cause the tubes to twist. Anything less then that it will be just fine. You don't have to be having a 4x4 look with the Dana, RMS even sells the street lynx kit for the Dana with coilovers, you just will being running close to stock ride height.
  25. YoungBlood
    YoungBlood Jolt the Squares
    448
    11
    Feb 9, 2007
    Western WA
    Local Time:
    6:28 AM
    Think seriously about this.
    Here's what I have spent from collecting parts: (I am picky and didn't screw w/ too much used sh*t)
    A-Body housing (REAL, AUTHENTIC):........................ $500.00
    Moser Alloy Axles (the good ones):............................$400.00
    NOS 3.23 Gears (Never Used):...................................$220.00
    Eaton Tru Trac:........................................................$545.00
    489 Case:...............................................................$200.00
    B-Body 11x2 Brakes (Refurb plates, new everything)...$335.00
    Crush Sleeve Eliminator fronm Dr. Diff..........................$30.00
    Yoke.......................................................................$120.00
    I still need to spend $500 on labor/bearings/seals/etc.
    Total will be around $2850. I love my car and staying true is important to me.
    You can save big depending on where you live (parts demand/labor cost) and if you aren't super-concerned about anything failing.
    I'm spending this money so I only spend it once.
    In the end, even if you knock off $500 from what I have in mind, a complete B-Body rear could potentially be had for 1/10 the cost.
    Dana would be close in cost. A 9 inch... well my dad could have got me a new unit through his company for $800, but you get the point. Call me stupid, it's okay. I regret nothing.
