Now, I'm pretty sure the reason the 9 in. and the Dana are "stonger" is because of tooth contact area..
Decades ago, I read a few articles that lead readers to believe that the bigger ring gear of the Ford and Dana, - spread the load to 3 teeth, as opposed to the 8 3/4 only had contact with 2 teeth..
And from the same sources, I was lead to believe that the 8 3/4 and the Dana shared the same pinion yoke, thus making the minimum diameter of the pinions of the 8 3/4, including the nefarious 741 "small pinion".. AND the DANA... all use the same yoke... thus same pinion size at the narrowest (weakest) point.. were the same....
As to the trans.. back in the day, - Ferds and Chebbie fuelers all ran MOPAR "Clutchflites".. before specialty tranny makers came along...
I'll wait to be corrected by our more knowledgable members..
That's pretty close, the 9" has the most tooth contact from the pin being moved so low on the ring, it has actually more contact area than any other diff.
However it has more power loss and even more stress trying to rip that pinion out than another diff, and the reason for that 3rd bearing NEEDING to be there and not there as hey lets make it even stronger...
The Dana has a better pin location, and larger ring, housing and tubes and will do more with all it's factory parts and no bracing than the 9" will do in factory form and no bracing.... you can live that same pic above using ford factory parts.
The pin on the 8.75 is larger than the 9" in two ways, length and diameter.
I have 8.75's in many classes of drag racing and even road racing, drag racing in just about every SS class, and in the more serious SS classes the move to the AL housing and Mikroniting the gears has given us the best results, but the NHRA just recently said the AL case is illegal, so we're back to the Factory style case, still using the Mikronite gears and we'll see if it was the Mikronite or something about the AL.
Before Mikronite and AL cases pretty much the best we could do was 2 full seasons before a tooth pulled, with the AL case and the mikronite i have had them beyond 3 seasons and still going, and now 5 of them are back in the stl case with more than 3 season and we'll see what happens.
However there is a issue with the AL case on the street, so don't run out and buy one, one AL case used on the street developed a noise after some time, i am believing that it needed a different adjustment to compensate for the AL movement when hot, something that does not happen in drag racing. I never bothered to play with it, just that i found it better to not use them for the street.
Again, at the higher hp levels of SS before Mikroniting we would get a tooth pull around 2 seasons or just over 2 seasons...
With a Dana i don't see you again unless you consistently drive thru wheel hop or tire shake (which is not smart, but it's done), but of both diffs the D-60 and the 8.75 when they do have a issue it is usually a R&P or axle, not the entire center housing, shaft and trans...
Yes the 727 can handle well beyond what some people are saying, just have to use the right builder.... not the guys using the parts of the pioneers and lack the rest of the knowledge.
