Hello all:
I'm presently battling the lifters in a 1989 factory roller-cam LA 360. It has not been rebuilt, but when I had it apart, it checked out super clean. It has a pair of Magnum heads on it - figured I'd go the whole Magnum route seeing that it had the factory roller cam setup in it already.
That said, when I got the engine, half of the lifters had been swapped out, as seen here:
Passenger's side on left, driver's on right.
Note that unlike what everybody says about these lifters, both of these have their oil delivery hole at a 90 degree angle to the spider.
I had a ticking noise coming from the driver's side though (later found to be cylinder #7's exhaust lifter jammed), and initially pulled each rocker arm on the driver's side to inspect each pushrod in case they were bent.
None were bent, but when I put the whole thing back together again, it clattered like nobody's business. Turns out three of the lifters weren't pumping up at all.
Now, I can't explain why three lifters just decided to give up the ghost. so I took the manifold and carburetor off for a closer look, and spun the engine. Apparently, not a single pushrod on the driver's side of the engine was spitting oil out the rocker.
I pulled the lifters to examine whether oil was pumping through the gallery. That checked out. I also moved a set of the "good" lifters from the left side of the engine to the right. The "good" lifters worked perfectly and squirted oil when placed on the driver's side of the engine (and were held down to the cam with my fingers, so that they didn't pop up too far).
Now, I went ahead and ordered a set of lifters from Advance Auto - a set of Sealed Power lifters (with the oil hole facing upwards). Dumped them in oil for a while, put them in...nothing. No prime/pump up after repeated cranking, and all the rockers have about 1/8" of slop if pressed.
Returned the Sealed Power units. Got a set of Melling lifters which look almost identical to the ones in the left side of the engine, only the fill hole is - again - at top. Again, I can't get the thing to prime even if I leave the engine cranking 20 times, even though the rest of the old lifters are squiring like tomorrow ain't never going to come.
If you want to read an even more detailed version of this saga, see: http://www.forabodiesonly.com/mopar/showthread.php?t=316085&page=9
Any suggestions?
-Kurt
Any suggestions?
-Kurt
