904 Deep Pan kit Question
ken5124
65 Valiant Signet
Winnipeg, Manitoba
Evening ! I am putting the Mopar Deep Transmission pan Kit on my 904.
Could someone please verify that I have the white plastic washer in the correct spot?
The rubber o ring sits correctly in the Spacer opening. I am presuming because there are no instructions that the plastic white spacer goes into the filter hole and the o ring side of the spacer goes up against the transmission body.
Thanks
The white washer is for the pan drain plug.
Nothing goes between the filter and the trans.
Anyone know an inexpensive source for the extension?
I have the pan but it did not come with the pickup extension.
I have only seen the with the pan as a set, but that does'nt mean they are not around.
A decent piece of aluminum and you could make one really easy.
They seal to the valve body, but not the filter so a gasket could be used for that.
ken5124-
Just read your post.
Doesn't 1965 have a (2) hole transmission filter for a 904?
[quote
Doesn't 1965 have a (2) hole transmission filter for a 904?[/quote]
Yes. The 2nd hole feeds the rear pump, maybe? When we did the deep pan in Jake's 65, we drilled a second hole thru the spacer. Matched it up the 2nd hole in the old filter. We then made the second hole in the new filter.
