1. ebigga67
    ebigga67 Well-Known Member
    188
    116
    Oct 10, 2014
    PNW
    Local Time:
    8:17 AM
    If I install a deep pan on my 904 is the full mark on the dip stick still the full mark, or will that overfill the pan? I have an odd leak I can’t track down and I think it’s coming from the overflow.
  2. Murray
    Murray FABO Gold Member FABO Gold Member
    2,591
    1877
    Apr 19, 2010
    San Jose, California
    Local Time:
    8:17 AM
    Pans are "deeper"- does not raise the oil lever unless you over-fill it.
    • Like Like x 1
    • Professor Fate
      Professor Fate Push the button, Max...
      2,480
      3375
      Jan 13, 2020
      Wisconsin
      Local Time:
      10:17 AM
      Shift/kickdown shaft seal, dipstick tube seal? both are notorious, especially if the trans is overfilled. You are checking it (running) on a level surface, in neutral?
    • Syleng1
      Syleng1 Karma is real and Life is short... FABO Gold Member
      2,380
      2054
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      11:17 AM
      Just make sure your pan comes with the drop down adapter for the filter.
      • Agree Agree x 3
      • Like Like x 1
