904 lock up trans
LA Dart
Indiana
What make a 904 trans a lock up trans??? i have got an 904 trans that i was told it was an lock up 904. can i replace some parts to make it an reg 904??
If its a lock up 904, its likely a 998 or 999. ITs a lock up because it allows the TC to lock up. The input shaft has a passage through the center that allows this function, as well as valving in the VB to operate it. You'll need a new input shaft and a VB. I do not recall if the cases are interchangable. It may simply be easier to find a non lockup 904 and use it.
After looking at it close it is a 904 lock up trans. ant it will take 625.00 to put it right and that 625 can go some wear else..i will stay with my 727 ..
