72scampguy
Will be buying a 904 for track car soon. 29x10.5 tire in a 3200# car. Full calvert steup in the rear. 700 hp small block. I think they offer a 1.54 and 1.74. Any advice would help.
Thanks.In my opinion, the low set it for a eng that don't have enough torque to get the best 60 foot out of the hole.
I think the lower set gears will only cause you traction problem.
700 hp you start to shy away from them low gears sets in the rear as well.
I would stick with the standard set.
Did not know that. Cool. I will check them out.ProTrans has multiple gears sets for the 904, give them a call & tell them what your plans are. They will be able to tell you what ratios you should run.
