ddart cart
Happy September!
I need help figuring out an issue with my 904 transmission, that is original to my 1974 Dart.
In PRND, all is well.
In 2nd, its behaves like it’s in drive.
In 1st the car doesn’t move from a stop and if you downshift to 1st the wheels lock up.
I hoped switching from column, to a b&m Z Gate floor shifter would insure the shift lever was getting it’s proper throw, and possibly solve the issue, but no dice. The Z Gate is properly adjusted, I took my time getting everything right on the install.
I’d like to manually go through the gears, access the higher rpm horsepower, and have the ability to downshift into 2nd and 1st.
I have a TF2 shift kit, yet to be installed, also. Maybe that will solve it? Idk.
Thank you in advance,
Doug
Doug
