i have a 73 dart sport, it was running and driving just fine, a nut came off a rod cap causing the rod to come loose, i pulled the motor, fixed the problem, put the motor back in, now i have no trans, i pulled the lines, and its not pumping, when i took out the motor i pulled the torque converter with it, and left the trans in, i only lost i tiny bit of fluid, and i replaced that, all linkage is hooked and working properly, when i bolted it back together it went smooth as pie, and i spun the torque converter several times to make sure it was seated before i bolted it home, and put the starter in, i've been a mopar guy for almost 50 years now, but i've never been very good with trans work, any idea's ?
