Hey guys!
I am having trouble removing my transmission coolant lines at the transmission. One is impossible to get to. The other as I remove the fitting I am twisting the line tight next to the fitting. It’s deforming.
How can there lines be removed given the access issue and the fitting issue?
These are compression fittings right? They should spin freely around the line right?
