airwoofer
Drivetrain limit explorer
So I finally got the trusty old 340 out of my fish and put in the 416 stroker. I rigged the kickdown linkage for the 904 so when the carb is strating to turn on the secondaries (manual) the kickdown was starting to get "tension" or feel like it was doing something. Full throttle coincides with full kickdown travel.
At the track for the first time and the footbraks launch was good (converter only about 2000-2200) and the 1st to 2nd shift went OK (I am shifting the car). When it came time to hit 3rd I thought I had overrun into neutral as the engine raced up to the 7000 limiter. I let up, down shifted and coasted across the line. The car did the same thing the next pass and on the third pass I noticed that if I let up as the engine raced as the tranny shifted to 3rd then stomped on the gas again the thing would shift faster but still has the issue.
Is my kickdown not adjusted properly? Should I "loosen" it up some?
Is the added power of the stroker causing havoc with the valve body or whatever inside the tranny?
The car was shifting fine (not in Drive but me shifting) with the 340.
