OK, here's the rest of the story. I changed my 7.25 out for an 8.25. I knew that I needed to shorten the driveshaft to account for the differences in the required length. A fellow had a bunch of Mopar parts advertised on Craigslist for months, including a driveshaft.
I measured and came up with the required length for the driveshaft and the one on CL matched my required length. So I bought it for $20. When I tried to install it, it was too long. Then I put it side by side with the old driveshaft and the transmission yoke was quite a bit longer. I changed the yokes and it worked perfectly. I was told that the driveshaft was from a 78 Aspen. It's the same as the 68 Barracuda shaft, only longer.
I may do the same rear end swap for a friend and was trying to be proactive about some of the issues we will also have with his car. Since he is having to drive 200 miles, it would be nice to have these issues handled beforehand.
Thanks, guys
