VSTwister
I'm looking into converting auto column to auto floor with OEM center console, and trying to make sure this will work before I take the plunge. This has been discussed before, but the old threads I've found have photos gone and I've not seen positive confirmation on this exactly:
Was the OEM auto floor console shifter setup originally intended to work with 904 cars? If so, what is different, if anything from the 727 cars? The reason I ask is in my research, I came across these old threads.
Console shifter pivot brackets - Info
904 transmission rod problem
When looking into the shifter pivot bracket (or gearshift control torque bracket), repros only mention it being used for 727s and I can't find anything to confirm if 904s have one or use the same.
1972 Dodge Charger Parts | MD2540 | 1966-74 Automatic Transmission Gearshift Control Torque Bracket | Classic Industries
1966-74 A B E-Body Gearshift Control Torque Bracket
So it all got me thinking...what else might be different?
Thanks for any help.
