right now i have a 904 with a 225 slant 6 i am going to do some performance upgrades. i need to replace the trans no matter what and was wondering if it is better to stick to the 904 or go for the 727.
I would agree. a 904 shifts the same and at the same points, has the same gear ratios but takes less horsepower to turn. Unless you're going to find 500 ft/lbs of torque and 500 bhp, you would be much better off with a 904.
Cool thanks everyone. Last thing, are there any modifications I should do to the trans I have heard of people putting in different gears and things is any of that necessary.
It'll depend on how much horsepower you're going to put through it and what you're going to use the car for. A street car build is going to be different than a drag car build. In their stock form, a 727 is a heavier duty transmission than a 904 but the 904 is the one to build, and after it's done, will be a stronger, lighter, less power-robbing than a stock 727.
