dragondan64
Banned
IMO you should have them flowed first to keep a record of what you got. Then you need to have cam specs so you can have them ported to flow with your cam or you can hurt performance and its easy to take material out but you cant put it back! Depending on what exactly you will use the engine for will help you make the right choice. Good luck!
