unclepunchy
Hi Folks, 73 Duster, 340, 4 spd.
I have no power from my column red wire to flasher relay and no power to my instrument fuse panel (3A) in the photo. All other fuses work. The fried section in the harness was for the heater which has since been removed. Headlights work, 4 ways, wipers work, etc. just no blinkers.
I recently took my dash panel out and cleaned it up, added some extra grounds and checked everything over. I also removed my dimmer timer relay thingy and all the wiring to the door buzzers. Obviously has something to do with that. Just need some ideas where to look next.
