Thanks again guys I really did not want to cut up a good console!
quote]
I was thinking the same thing about cutting an auto console top..............IT WILL NOT WORK, you will have to get the 4 speed top, hump and 2 boots
I converted mine to a 4 speed, had already welded the brackets in for the auto console, removed the shifter and brackets then welded in hump, I guess it is in the right spot
The 4 speed top had a place in it that the shifter had been hitting before I got it. It was repaired and rechromed and I have not hit the console with the shifter yet
You might want to check on the shifter and console cost before you go that route. The shifter looks like a broken rear dog leg and don't know if they are still available from anyone except ebay
