a body big block exhaust manifolds
yeh and try finding a pair of m-codes
Yes, I know they are hard to find, but , I was just pointing out that they DO make them (or made them). I understand that ~'69 or so C-Body drivers side manifold works the best...it's tucked in around the A-Body steering column area. Not correct, but do work. The "BigBlockDart.com" site has a whole section devoted to this.
P.S. I dont need to find a set... I have a set.
Those, unfortunately, are not M-Code manifolds...they are 383, 1967 ones. Depending on your installation, they might work on a 440 A-Body...you'd have to test fit them on your car to be certain. 440 (M-codes) drivers side is longer just above the steering-column-wrap-around area.
Check this site out for the correct casting numbers and application of these...
http://www.dartstechsite.com/exhaust_castnumbers.htm
I know this is an old tread - but I would appreicate anyone who could point me in the right direction or has a set they are willing part with.
Left side 2899002
Right side 2806900
Thank you Dan in New York 12590
845-546-5523
Thanks very much. Do you have a contact number for your friend with the A-body BB manfolds ? And a name. Or if you would please,
you can have him call me anytime 845-546-5523. Dan in NY 12590
I sold a set of the 383s a couple of months ago.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230454980312&viewitem=
I have one set left that has weld repairs. I don't really want to sell them, but $800 might convince me. I would rather bring them to you at Carlisle and let you look at the welds, then decide if they will work for you.
