[SOLD] A-body drivetrain part out
dpmalibu
Hatboro,PA
All parts came off of a 1973 Duster:
I just recently parted out a 1973 Duster. I have parts are drivetrain related except for (3) items:
Manual disc brake set up. Includes the following:
Master cylinder and Prop valve, spindles,rotors,calipers,(newer) brake hoses, Upper and lower control arms w/ new bushings. Lower control arms have sway bar brackets welded onto them. $225
HD torsion bars : part # 454R /402 (bottom #) $80 (They are 1 1/8" thick)
Driveshaft for 727 trans w/ 8.25" rear $75
8.25" rear w/ new 3.90 gears. Spider gears are welded (poor man's spool) $275
(2) driveshaft loops $30pr.
set of 4 Monroe shocks $45
V8 throttle cable $15
5" Autometer Tach w/ recall $100
Accutech gauge panel w/ 2 5/8" water temp/oil pressure gauges $75
Push button start/toggle switch mounted to Sppeedway motors panel $20
Quick Release steering wheel $40
Rebuilt 340 low miles. Runs great no smoke, leaks or funny noises. (have video of car running can show you if you cone in person) $1875
located in Hatboro,Pa
pics coming shortly
I am interested in the 8.25 but only if it has the 5x4.5 bbp axles and will fit under my 65 Barracuda without much hassle. What would shipping be to area code 48044.
Thanks
Welded spiders - bad idea for a car that is used on pavement.
Hi....I am interested in the v8 speedo cable...will that work on any small block mopar v8 and a holley carb ?
Thanks
ian.
took closer pics of block to show that the freeze out plugs are new and block has that gray paint/primer that is sometimes put on new motors if they are crate motors. Hard to tell from top pics that motor is a newer rebuild. I probably should clean it to make it easier
I was interested in the torsion bars but I'm not finding those part numbers anywhere? Any idea who made them?
I have no idea who makes them. They are pretty thick so your suspension probly would be pretty stiff. I would think these would be could for like a big block car or a car built for a road course. These were in a duster circle track car.
this is what is left:
5Pair of leaf leaf springs $75
Rebuilt 340 low miles. Runs great no smoke, leaks or funny noises. (have video of car running can show you if you cone in person) $1800
8.25 rear w/ new 3.90 gears (spider gears are welded) $250
