dpmalibu
All parts came off of a 1973 Duster:
I just recently parted out a 1973 Duster. I have parts are drivetrain related except for (3) items:
Manual disc brake set up. Includes the following:
Master cylinder and Prop valve, spindles,rotors,calipers,(newer) brake hoses, Upper and lower control arms w/ new bushings. Lower control arms have sway bar brackets welded onto them. $225
HD torsion bars : part # 454R /402 (bottom #) $80 (They are 1 1/8" thick)
Driveshaft for 727 trans w/ 8.25" rear $75
8.25" rear w/ new 3.90 gears. Spider gears are welded (poor man's spool) $275
(2) driveshaft loops $30pr.
set of 4 Monroe shocks $45
V8 throttle cable $15
5" Autometer Tach w/ recall $100
Accutech gauge panel w/ 2 5/8" water temp/oil pressure gauges $75
Push button start/toggle switch mounted to Sppeedway motors panel $20
Quick Release steering wheel $40
Rebuilt 340 low miles. Runs great no smoke, leaks or funny noises. (have video of car running can show you if you cone in person) $1875
located in Hatboro,Pa
pics coming shortly
pics coming shortly
