A body front end body dollies
Mopar Exterior Parts For Sale
Thread Status:
  1. crackedback
    crackedback FABO Gold Member FABO Gold Member
    17,956
    2079
    Aug 7, 2005
    92201
    Local Time:
    9:52 AM
    I would ship to Canada using only USPS.
    If the total is less that 20#, I believe I can get them in a large flat rate box which would add $25ish to the total, figure in the 315-320 range. If they can't go flat rate box???? No idea what it would run to get them there. Probably in the $70 range.
    If you can get casters locally, I know for sure the weight would be below 20#
  2. desotoman
    desotoman Well-Known Member
    117
    4
    May 10, 2012
    upstate n.y
    Local Time:
    11:52 AM
    do you have the front and rear A-body ready to ship ? need a price for all 4 w/the 650lbs wheel to area code 12053 N.Y thank's
  3. firstgencharger
    firstgencharger firstgencharger
    12
    0
    Dec 21, 2012
    Dearborn
    Local Time:
    12:52 PM
    hey crackedback, i saw this solution of yours and was wondering if u would consider making a set (front/back) for a b unit body? ive got a 67 charger and these seem totally awesome, besides what fabo's have said about the quality of them.
    i wont need the casters if those are standard at HF. watcha u think?
  4. crackedback
    17,956
    2079
    Aug 7, 2005
    92201
    Local Time:
    9:52 AM
    I can build them.... my dad has this ultimate set of tools... sorry, spicolli flashback. :)
    I would need the center to center spread on your bumper bracket bolts.
    If you want the car level, get the rocker level and get me these measurements.
    1) From center of front bumper bracket bolt to ground and
    2) from rear spring mount lower bolt hole to ground.
    3) yoke to ground.
    I can build it off those measurements. If you want it a bit taller let me know how much.
    I'd need to know the bolt pattern for the casters you plan on using. The ones I normally build are 4.5' x 4" plates.
    [​IMG]
  5. firstgencharger
    12
    0
    Dec 21, 2012
    Dearborn
    Local Time:
    12:52 PM
    ill get back to u shortly
  6. firstgencharger
    12
    0
    Dec 21, 2012
    Dearborn
    Local Time:
    12:52 PM
    RATS! we had a good stretch of mild weather where i coulda got the measurements, but now its snowy and cold. i will have to empty the car out to get it level. i have everything inside that i took off. next good spell we have i will get the info to you.
    thanx too much
    • Like Like x 1
    • FJRdoc
      FJRdoc FABO Gold Member FABO Gold Member
      916
      329
      Dec 29, 2009
      Brownstown, PA
      Local Time:
      12:52 PM
      Just got a pair of front and back dollies for my Duster. I'm not ready to attach them yet but I am very impressed with the quality of construction. It's great to support a FABO member and it's made in the USA!!!
    • plugger340
      plugger340 Well-Known Member
      343
      33
      Dec 7, 2010
      Red Deer, Alberta
      Local Time:
      10:52 AM
      Hi Crackedback;
      How much would it cost to ship a pair of front and back dollies, without casters, to
      T4R 2T8 (Red Deer, Alberta, Canada)?
      thanks
    • crackedback
      17,956
      2079
      Aug 7, 2005
      92201
      Local Time:
      9:52 AM
      They fit in a large flat rate box. At most it would be $54 via usps.
      If you know a better or less expensive way to ship them, I can look into it.
    • 71Scamper
      71Scamper Mopar runs thru my veins!
      1,305
      20
      Feb 5, 2013
      Salem, MA
      Local Time:
      12:52 PM
      Oh friggin crap! I just made a setup today similar to this. I would of much rather of just bought them instead of wasting a full day fabbing them up!
      Good looking pieces!
    • crackedback
      17,956
      2079
      Aug 7, 2005
      92201
      Local Time:
      9:52 AM
      Thanks
      If you want them for the rear, I make those...
    • mbaird
      mbaird mbaird FABO Gold Member
      4,128
      1364
      Dec 10, 2005
      boise, Id
      Local Time:
      10:52 AM
      Made my own. Yours are better! Just bought some inflatable 8" wheels from harbor frieght.
      They suck! Use the solid ones like he does. Moves a lot easier.
    • 71Scamper
      1,305
      20
      Feb 5, 2013
      Salem, MA
      Local Time:
      12:52 PM
      Already got the rear all together, but thanks. just working on finishing the front tub and suspension work
      lol I almost bought the 8" pneumatic casters today then decided on the solids because I figured the solids would handle the weight better.
    • crackedback
      17,956
      2079
      Aug 7, 2005
      92201
      Local Time:
      9:52 AM
      I can make these and bring to spring Fling with prepayment.
      I'd need a couple days lead time as casters would have to be ordered if you wanted them.
    • crackedback
      17,956
      2079
      Aug 7, 2005
      92201
      Local Time:
      9:52 AM
      Got more casters. Materials and casters have both gone up a little in cost, going to keep the selling prices the same.
      The rears are being made using 3/16" steel plate. Fronts are 3/16 caster plates and 1/8" uprights/mount bracket where the bumper bolts attach. Towed a car on a trailer almost 300 miles, not an issue.
      Shipping on a complete set is about $30 anywhere in the continental US.
    • 68fsh
      68fsh FABO Gold Member FABO Gold Member
      444
      19
      Apr 10, 2009
      Local Time:
      11:52 AM
      How much for the front and rears without casters? I know this questions has been ask
    • crackedback
      17,956
      2079
      Aug 7, 2005
      92201
      Local Time:
      9:52 AM
      200+ shipping
      Those can fit in a flat rate box, with insurance, shipping is about $20 in US
      I have a set ready to go right now.
    • dart4forte
      dart4forte FABO Gold Member FABO Gold Member
      4,157
      570
      May 28, 2004
      Mesa, AZ
      Local Time:
      4:52 PM
      Just a word of caution when hauling a car body using casters. When rolling a car body into the trailer the castors will gouge the hell out of the floor of your trailer. You'll need aluminum plating to spread the load.
    • woody30
      woody30 woody30
      2,392
      19
      May 13, 2012
      walton ny
      Local Time:
      12:52 PM
      Those are awesome. Nice work.
    • crackedback
      17,956
      2079
      Aug 7, 2005
      92201
      Local Time:
      9:52 AM
      I could see skinny metal casters doing that to a plywood deck.
    • crackedback
      17,956
      2079
      Aug 7, 2005
      92201
      Local Time:
      9:52 AM
      Have a set ready to go.
      I can also make them slightly taller.
    Thread Status:
