[WANTED] A BODY PARTS
I have the crossmember from a 70 Duster along with the starter bolts but what trans bolts do you need?
I have all the bolts that you need plus the crossmember.
PM sent.
Ken
Just to help, If you are doing 70 correct. The cross member for 1970 have the small holes
I really don't know the size bolts that it has its a70 dart swinger the car come originally with a slant 6 so I'm assuming that I'm gonna need another cross member if the one I have will work great right now my car sitting on the trailer
Your cross member should work. So will the starter bolts I believe. The trans bolts I'm not sure of though.
The crossmember from your slant six is the same as a v8 any automatic or four speed. Except for the bolt size difference mentioned above you can use ANY A body crossmember from 67-72. Since you are not doing "numbers match" don't worry about the size of the bolts.
