A Body Rear Help Axle Swap
scottylack
NEW JERSEY
Looking to fill my A Body 8 3/4 with BBP axles...
where can I get them from that will fit my rear...? Will 73-76 Duster/Dart rear axles work for this? Will they go right in? Will the drum brakes work with this and match up to the rear??? HELP!
73-76 duster or dart rear axles will probably be from an 8.25 axle. I got my yukons with green bearings and 3 inch studs from Mancini. Got the brakes from a 74 Pick up (10x2.25). everything from plates to drums for $50.
There wasn't a 8&3/4 with bbp from the factory and other factory axles wont interchange. Aftermarket axles are the common solution.
C body or truck axles, shortened and resplined.
Aren't any direct swap axles in BBP for A body rears from other factory rears.
