A Gasket or what heater core at firewall
Enjoying it again
Ontario
Hello Guys. Need a little help. Please and thank you. Where the heater core pipes go through the firewall is there to be a gasket or something to stop metal pipes from rubbing on the firewall? Is so what is it called and where can one be found?
Here's a picture of my 66 heater box. The bracket helps keep them centered as well as the plate with a mounting hole in the center.
By the way, it was probably the first time taken apart in 55 years!!
