a n fittings
Mopar Al
MOPAR AL
Western Pa
I have a 85 Ram restored. Bat, 15 gal fuel cell in bed. The problem is with the 6an 90* fitting on the pickup line. New fitting is tight where the hose slides over male end ( blue nut ). But when I assemble the hose the blue nut is no longer tight, and leaks. Seems like the hose and red nut loosens p the seal on the blue end. What am I doing wrong ?
can we have a pic please. have a hard time picturing what youre saying but i will give it a shot. if the blue nut is a bulkhead fitting thru the tank it has a nut on the inside and a nylon washer on each side of the tank body. I had to take the 10 small bolts loose and pull the fill flange,remove the foam and back up the nut inside while tighteneng the bulkhead fitting. Hope this helps.
