MoparDart68
19 here...
The question about which direction water drains is a myth. Water going down a drain is not affected by the Coriolis effect. Water will drain in either direction whether you're in the northern or southern hemisphere. It also doesn't drain straight down if you're on the equator. That question should be thrown out, so everybody should take their score out of 24, not 25. The maker of the quiz needs to go back to elementary school.
