Hi guys
I have an A518 / 46rh transmission in my old 1972 Australian charger. I have set up a toggle switch to put it into overdrive when i want it. I have not tried the converter lock up though as I don't know if it will work with my converter.
It has a Dacco 2800 stall converter in it. With this not being a stock converter will the lock up still work? I don't know if it is something in the box or converter that makes it lock up? is the converter a special converter to lock up?
Also i am looking at buying a A500 / 42rh transmission. I asked the seller and he said his one has the 3 pin plug not the 2 pin. Does this mean it is a lock up unit as well or were the A500s just overdrive with no lock up.
thanks Maca
thanks Maca
