Swapping converters now that I’ve developed a leak at likely the pump seal, refreshing things and will be relocating the case vent just because. Has anyone modified their case (pump) vent, either plugging the existing hole in the pump and relocating it to the top of the the extension housing (as shown in the Carl Munroe book) or located it someplace else? With my top mount short extension housing I will need to locate it elsewhere, possibly just behind the mount (red mark as shown) or I could even run a 90 degree fitting on the pump vent hole and run a line up through the top of the case, as there is a convenient hole in the case already, to a small catch can/breather what have you. Considering that option as I have plenty of clearance with the 9-1/2” converter I’ll be running. Just looking for any options that work, not opinions as to whether I need to do it or not. Anyone?
