1972orangebeast
-earlier a833 cast housing, good tranny needs new side case gasket leaks a little. $400 pick up
-Pre 71 10.5 bell housing, it fits a body and early a833 been powder coated, rear main leaked over it but will clean up nice no chipping of the powder coat, plus fork pivot, and ball stud bracket $150
-Mechanical 340 rockers off a 69 motor, great shape have shafts and all spacers and rockers $200 plus ride
-Hooker Headers cermic coated, good shape bottoms are dented a lil from road (like they all do) cermic is pretty good shape still. $100
-KYB shocks with around 3000 miles on them, good condition prob need repainted due to trying to clean one with a little bit of brake cleaner and ate some of the paint ops: $50
-Everything for power brake conversion, booster and master cylinder and brackets, pedal rod. Master cylinder is for front disc and rear drum. $75
-Will have a whole 73 kframe for sale with disc set up and proportioning valve end of February also if you want whole set up ill make a deal and possibly deliever if you in route of my trip. between Florida and Ohio.
Im located in Newark, Ohio 43055 will make deals on multiple parts and shipping
