TheMoparKid
New Member
Having trouble Installing the front pump in my 904, even with guide studs it kept cocking slightly to the side. The solution was to take the pump apart, realine the bolt holes (that go through the pump into the trans housing) and then re tightening the pump bolts. After that it fell right into place!
Thought this post might help save someone some time taking the pump in and out scratching their heads. Cheers
