jpeshelman
This was first an occasional problem, now the car wont move......As soon as you put the car in gear and give it any throttle it will stall out like its tight. The car will idle fine sitting and you can put it in gear with your fott on the brake, but it seems to load the enigne so hard and stall it out. When i purchased the car, they said the torque converter was bad. I drove the car up on the car trailer and around my house for a couple months before this problem came up again. I dropped the transmission pan and checked to see if the filter was clogged or if any debri was in the pan....nothing. I have since pulled the torque converter and transmission....torque converter tested out fine...does anyone have any idea what can be wrong with the transmission?!?!
It will do it any forward or reverse gear....any help would be greatly appreciated!!
