PocketAces
I have the A999 in my 1940 dodge coupe,,,the motor is a tiny first hemi, 1953 241C,I. WITH 7.1 compression,,and a over sized hemi grind cam,not my doin,,, from what ive heard the 999 has a lower then normal first gear ratio,,,the car weighs around 3000-3200 has A 3.23 rear gear,,,it idels at 8.25 rpm.,,,in netrual and drops to 6.25 rpm in gear,,gets out of the hole pretty good we are talking less then 200 horse power,,, i dont know how or what but as far as i know no machine work has been done to the crank for the larger hub,,,,,the early hemi ,s must have a bigger convertor register hole,,,, any way no need for giant horse power to run this trans,,,it goes down the highway at 80 mph with the A/C on 18mpg,,,
Is yours a lockup torque converter? What size rear tires?
