About To Install My 06 Hemi In My Duster Any Help???
swifter
wis
Hey who has done this before would like to know any issues that went on with the install 70 duster-06 5.7 hemi with xv package,tti headers and mounts:bootysha:
Several good build threads here and on BBD about doing the swap. I am doing a 6.1, but my direction is a little different.
If you plan on AC you will have some fitment issues with a car 5.7 (lower mount AC compressor) Pretty sure the truck mounts them up high
Pics as you progress plz!.....
I am working on a 67 Dart with a 5.7 06 Hemi. To say the least you will not get bored. I had to trim out a little for the alternator and fabbed my own engine mounts. The motor is extremely tight between the inner fenders on my dart. I have long tube header from TTI ceramic coated and polished. They fit snug with my manual steering, no way would power steering would have ever fit. I used a double wobble joint in my steering rod to clear the headers. I had to move the power brakes canister/master cyclinder to drivers side approx 2 inches. I also had to insall a different oil pan to clear the steering and k-member. I just received my XV throttle body and intake this week, so I can run a filter thru my hemi scoop on my hood. Is this the set up you are going to run?? I am waiting to install the intake as soon as my cam package arrives from Frank Racing. I am still doing body work till the parts come in. This is a few things I have run into so far, not sure if it will affect you on your 70 duster. You might check members restoration forum here.
