[WANTED] Accelerator linkage components for 1967 Barracuda 273 Commando 4-speed 4-barrel plus timing pointer
Capecodcuda
Cape Cod
Hi,
I'm trying to pull together the finishing touches on my 4-barrel 273 with manual transmission. I have the accelerator cable and the carburetor but basically need everything in between: cable bracket, linkage, springs, return spring bracket, etc. Maybe someone has the complete setup available?
I'm also looking for a bolt-on timing pointer for the front of the engine.
Thanks for any leads,
Steve
I have some of this stuff. .Not sure of it's original fitting.
Hi,
Steve
Post #3 second row right is a manual 4 barrel carb bracket. Not sure if it is a 273 or 340, either will work. Good luck finding a 67 Commando manual throttle cable bracket. I'd just run a 68-70 340 return spring and a factory spring bracket. Maybe a 2 barrel bracket bent to line up with the spring and carb attachment.
I added a small bracket on top of the OEM to raise the attachment point running into a Edelbrock LD4B
Thanks for this.
Al, I will reach out by private message in a day or two. I'm trying to figure out what else I need that you might have.
I'm leaving the thread open for now for the timing pointer and other linkage components.
