[WANTED] Adj. rocker arms and pushrods
You will need to measure for the correct length pushrods because these usually were run on the early 273's and the pushrods will be too long. I got luck and ended up with 5 sets of pushrods that were different lengths for each set and one set was the correct length. Wolverine (I think) is the name of a company that makes a pushrod length checker that you can use to get the length correct. Be sure and measure at least 2 intakes and 2 exhausts on each side before ordering your new pushrods. I know that Mancini has them and I sure there are others who offer them.
If your gonna run hydraulic lifters then you will neen different length pushrods i have a new in the package set of comp pushrods made just for what your doing part #7821-16 ile take $45.00 shipped if your interested send me a pm.
make sure cup to ball , ball to ball , I do have a set but sitting on motor yet , I do need a set of valve cover plasric wire inserts to hold wires in tight 273 or 318
