jacksdodges
jacksdodges
Is their any advantage to run adjustable roller rockers when your running a hyd. cam?
Rollers have less side load on the valve on a big lift cam, they are more precise in their ratio and look cooler. On huge cams, they can roll right off the valve tip so lash caps need to be used. Other than that, there are longevity issues, they are almost all ALuminum so they are not the strongest you can get, and roller bearing models need a hardened shaft. Make sure the shafts have the oil holes on the bottom and are pointed inboard. The notches in the shafts are always on your left and down when facing the spark plugs
