downsr
Anyone use a adjustable pcv valve.Have stroker engine that had some oil leaks that have since been repaired.What to make sure that i am not building pressure in crank case.Would get oil leakage on top of timing cover after wide open throttle or cruising around 2500 rpm for a few miles.The engine is a 340 stroked to 416.Have breather on pass side running to air cleaner.PCV valve on other side run to fitting on intake.And how should pcv work at idle opposed to wide open throttle.Just have stock pcv valve from auto parts store on it now.Sometimes i can hear a rattling noise from pcv valve and other times i do not.Do not know much about the adjustable pcv valves and how the pcv valves should work.Thanks
