dodgedifferent2
The next generation adjustable proportioning valve from Wilwood combines the latest refinements in manufacturing processes and materials to deliver precise pressure metering and unyielding strength from its compact and lightweight forged billet design.
Precision proportioning from 100 to 1,000 PSI. At full release the valve is capable of up to 57% reduction in line pressure. The new smaller body accommodates easy mounting in a variety of locations in conjunction with two .25" diameter holes on 1.00" centers. Along with standard 1/8" NPT inlet and outlet ports and two 1/8" NPT to 3/8-24 inverted flare brake line adapters included with each valve makes installation simple.
Note: Wilwood suggest using DOT 3 or DOT 4 brake fluid in all of their brake components. DO NOT USE DOT 5 SILICONE FLUID
I bought this and have no use for it now.
42.00 + shipping
located ontario canada
42.00 + shipping
