Easier to set & keep preload & adjustability.
Yes adjustability. It depends on your cam specs. Unnecessary with a stock or near stock grind.Is there an advantage to running adjustable rockers on hydraulic lifters?
Engine masters played with this a while back. It does make a difference but you're only going to see it on the dyno, it was small. just barely outside of the dyno's margin of error.Yes adjustability. It depends on your cam specs. Unnecessary with a stock or near stock grind.
It would be interesting to see on a dyno if there is any performance advantage if any.
In that case may be so. Voodoo's are a little noisy anyway from what I understand.I have a Lunati vodoo cam. On the bigger side. Running double valve springs. They clack a little. Wondered if adjustables would help.
