adjusting torsion bars
68 A
Auburn, NY
Rebuilt my front end, got the car back on the ground, and the service manual tells me that i need to adjust the torsion bars to the correct ride height. However, they do not give me the correct height or where to measure it from. I'm sure someone here knows and can help me with it.
Thanks
Steve
I didn't follow the service manual. I adjusted the preload until I liked the ride height that gave me the proper look. I then took it to the alignment shop and had it aligned. Been driving it for over 15 years that way and have had no problems.
Rod
With the wheels straight ahead, the factory calls for measuring the distance between the tie rod ends and the floor. The factory gives a specification for how much higher the inners are supposed to be than the outers. You want the difference on each side to be the same. The MOPAR Chassis book goes into some detail regarding the procedure, but basically you want the inners slightly higher than the outers. Never lower.
Or just say "screw the bumpsteer", set it where you think it looks good and hope for the best.
Ride height is NOT measured at the tie rod ends. You may use the eyeball and then align it trick and if you dont put hardly any mileage on it in the course of the year you'll probably never notice or care enough that it is wrong. I prefer to do it correctly myself and know that my tires will last at least half of the claimed 50,000 miles I should get from them (hard to do when you burn the backs off to often, LOL)
The correct way to set the alignment depends on the year and the body style, but as for the A bodies, car must be on flat level surface sitting on it wheels, you measure the height from level floor to the bottom of the ball joints on lower control arm, then you measure from the ground up to the edge of the adjusting blade (the piece that the adjusting screw pushes against in between the halves of the lower control arm, or as the service manual calls it the "torsion bar spring anchor housing"). The difference in height (spring anchor housing measurement-ball joint measurement=ride height) is the "ride height", both sides need to be as close to the same as possible. Ride height for 67-70 A body Dart and Valiant and 67 Barracuda is 2 1/8" +/- 1/8", 68-69 Barracuda is 1 3/8" +/- 1/8".
Set it incorrectly and you may have severe bump steer, you can cause steering components to hit/bind, cause sever tire wear, make the car difficult to handle, and or a number of other possible problems. The engineers didn't sit and twiddle there thumbs when they designed the suspension in these cars and, if set up properly, they handle VERY well.
I have included a picture of a lower control arm with an arrow to where your supposed to measure to the "adjusting blade" on it.
