After market steering columns
I know this is an old thread, but I wanted to revive it instead of starting a new thread. Is there an aftermarket steering column that can be used with the stock firewall? What length are you guys using?
I used an IDIDIT shorty tilt column with a 3/4" DD steering shaft. I made a slight change to the factory firewall plate to install a 3/4" bearing for the steering shaft. This was the simplest way to go for my setup at the time.
Sacrificed the old column
Welded the mounting plates from the original column to the IDIDIT.
Original firewall plate
Mock up pictures
This was fairly straight forward without having to do a whole ton of fabrication work. The DD shaft has some sort of chromate finish on it and I bought a stainless u-joint to adapt to the FR steering box off ebay for $40-$45. So far I've been happy with it. The DD steering shaft also provides some extra room around the headers over the factory column.
