After the engine overheated, I found some weird gunk in my radiator
Schneiderman
Long Island, New York
I got stuck in traffic driving my 1972 Coronet in the city today, the temp gauge never went over 3/4 of the way, but when I parked and turned off the car, steam billowed out and a bit of coolant spilled too. After letting it cool down I opened the radiator cap to put in some distilled water, but I saw two pieces of some weird gunky substance. I managed to fish them out, I have no idea if there is any more in there that I can't see. I'm just here to ask if this is normal or something I should worry about. I really NEED the car first thing tomorrow for work...
I do not remember what coolant was in the engine, which is a somewhat recently rebuilt 318.
I would just drain out the cooling system, then put some fresh coolant in it and give it a try. Remember to add some antifreeze, it actually helps your engine run cooler than straight water!
Also sounds like with the coolant puking you might want to install overflow bottle. Check cap gasket also. Ditto the flush and fill w/antifreeze! Good Luck!
Drain ,flush and check the thermostat. I'd be looking for some gasket material or sealer/permatex that loosened up . It may be hindering your flow .
